Main Feed Line Routing
Old Feb 5, 2011 | 01:37 AM
SRTKLLR's Avatar
Thanks, guys. I ran out of time and wasn't able to get everything buttoned up for tomorrows race at Fontana.
I was going to just do the easiest way and only run the WOT micro switch and try and use the purge button by hand to trigger the nitrous. I ran the main line all the way to the back but was like 3ft short in order to put the bottle in the bed by the tailgate.
Later, I picked up a piece of steel and cut it to fit where the jack support goes. Bolted the bottle brackets to it and mounted the bottle up. I also had to make new hard lines for the plate kit.
Will be back at it after tomorrows races. I will be using the progressive controller and NANO.
Old Feb 5, 2011 | 02:23 AM
Mangled03gmc's Avatar
Baltimore Whore
I ran mine down the fire wall, above the heat shields, up into the cab directly under where the fitting was for the line on the bottle.. Had to drill the hole to do it.. I was going to run my blow down out the same hole that the nitrous line cam in..
Old Feb 5, 2011 | 08:33 PM
LS1TRUCKGUY's Avatar
The white wire on the back of the cluster will work for rpm signal. The purple wire on the tps sensor will w Work for wot trigger voltage. I ran all my wires through the grommet the main harness comes through on the drivers side firewall
Old Mar 30, 2011 | 06:51 PM
TxStVanWilder's Avatar
when i had my bottle mounted in between teh seats i ran the line from under the carpet, under the dash and through an exisiting hole on the drivers side. then covered it it in black tubing along the firewall so you couldnt see it
pewter00
Dec 13, 2015 10:38 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
gavin2005
Sep 13, 2015 09:04 PM
Pimpinpete
Sep 8, 2015 07:39 PM
mayko
Sep 7, 2015 12:24 PM
