lean cutt off switch
what would be the best o2 sensor to tie into ,i am hooking up a lean cut off and it will work with the factory narrow band just not sure which one to use ? i have 4 of them two before the cats and two after ?
I believe it is the fronts as the rear O2's are to see how efficient the cats are.
For the lean and rich a/f cut-off to work I think you need to use a wideband O2 sensor but for the lean you may be ok with the stock ones. |
i just checked my stock sensor they have 4 wires does any one know if these are wide band ? or narrow band . also i was mistakin i only have one after the cat . it too has 4 wires
they are just a heated 02 sensor. they have an open and closed loop cycle, the readout to the pcm is in Mv. The front sensors monitor lean/rich condition, and the rear monitor cat efficiency.
Dynotune (LS1Tech0 sponsor sells a lean cutoff switch
http://www.dynotunenitrous.com/store...p?idproduct=67 |
| All times are GMT -5. The time now is 02:34 AM. |
