lean cutt off switch
Old Jul 1, 2011 | 05:00 PM
6789olds's Avatar
Default lean cutt off switch
what would be the best o2 sensor to tie into ,i am hooking up a lean cut off and it will work with the factory narrow band just not sure which one to use ? i have 4 of them two before the cats and two after ?
Old Jul 1, 2011 | 06:21 PM
SRTKLLR's Avatar
I believe it is the fronts as the rear O2's are to see how efficient the cats are.
For the lean and rich a/f cut-off to work I think you need to use a wideband O2 sensor but for the lean you may be ok with the stock ones.
Old Jul 1, 2011 | 07:35 PM
6789olds's Avatar
i just checked my stock sensor they have 4 wires does any one know if these are wide band ? or narrow band . also i was mistakin i only have one after the cat . it too has 4 wires
Old Jul 14, 2011 | 06:32 PM
Chevy_King1500's Avatar
they are just a heated 02 sensor. they have an open and closed loop cycle, the readout to the pcm is in Mv. The front sensors monitor lean/rich condition, and the rear monitor cat efficiency.
Old Jul 16, 2011 | 09:43 PM
JoeyGC5's Avatar
Dynotune (LS1Tech0 sponsor sells a lean cutoff switch
http://www.dynotunenitrous.com/store...p?idproduct=67
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
