Help with setting up Window Switch
I installed wetshot nitrous on my 2001 silverado today, gonna finish all the wiring tomorrow. I need to wire in the window switch and then adjust it. My rev limited is set for 6500, and I have 3600 stall. Needing guidance on my ativation and deactivation points. I was thinking of activating at 3800 and deactivating at 6300. Does this sound correct? Also, will the window switch spray through the shift point if my shifts are set for 6200?
Also, what size shot would I be good with? Gonna start at 100 first and then work my way up to 200 Lq4 6.0 bored .030 over 243 stage 3 heads (patriot performance) Diamond forged pistons (9.41cr) Eagle h beam rods Stock crank Aeromotive stealth 340 fuel pump |
I would have it shut off 200rpm before the shift (if you don't want to spray through), and the shift 300rpm before the rev limiter. That is actual shift point, which will probably be different than where you have it set in the tune. I would start with a 50 shot and work up from there. Keep in mind as you up the power you are going to need to lower the shift point in the tune.
Ok, that makes since. Thank you
I like to activate mine 2800-3000. Just don't brake stall into the nitrous. I like to spray mine through the shifts it's so much better but it's always been on a built trans.
| All times are GMT -5. The time now is 06:23 AM. |
