Help new to nitrous lq9 Procharged
Old Mar 22, 2016 | 11:56 PM
murderedSS's Avatar
Default Help new to nitrous lq9 Procharged
Hello guys and gals here's the run down I have 2003 Silverado SS with a full forged lq9 (364ci) Procharged running 15psi right now may bump up the boost a little but that's not important right now 317 heads with a PandP job fastrt 102mm intake with an ls2 tb 1000cc injectors and fast rails! Wanna run a 75 to maybe 100 shot tops nothing crazy
And now to my question I have inquired a few parts for my nitrous setup but not everything I got 2 10lb bottles full bottle warmer brackets to mount it and lines to get in my engine bay. That's all I can think that I have off the top of my head. I know I'm gonna need a plate solenoids all the wiring and maybe a purge system not sure what else I need to get this kit installed and advice would be helpful thanks
Old Mar 23, 2016 | 08:30 AM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Don't forget a window switch.
Old Mar 23, 2016 | 09:19 AM
Atomic's Avatar
I have a gauge for that
Mandatory stuff:
-Bottle with valve
-Way to secure bottle from moving
-Nitrous solenoid
-Nitrous line from bottle to solenoid
-Nitrous jets
-Fuel jets (if using a wet shot)
-If doing a wet shot, fuel solenoid and line to connect solenoid to fuel source
-Plate or nozzle for nitrous/(fuel)
-Way to activate system (manual or automatic)
-Relays and wiring to power the solenoids
Optional stuff:
-Electronic or mechanical window and/or throttle switch
-Bottle pressure gauge
-Bottle heater/blanket/cooler
-Fuel pressure safety switch
-Bottle temperature control with temp or pressure sensors
-Purge solenoid with line pointing somewhere
Old Mar 24, 2016 | 01:25 AM
murderedSS's Avatar
Thanks a lot
jasonst
Apr 7, 2016 08:50 AM
Tootall
14
Feb 29, 2016 08:31 AM
gallo-lo
Feb 19, 2016 06:52 AM
gbbmk
Feb 17, 2016 04:20 PM
02_Orange_D1SC
Feb 8, 2016 11:41 AM
