A Few ? About Nos
I just bought a N.X. wet fogger system...How big of a shot should or can I go without having to worry? Also I wanna try run it the whole 1/4... Will it be okay? Also do I need a retune for it?
Congrates on picking a good system.
I would suggest having your tune looked at since it has been tuned. You should be good for a easy 100 hp. You could safely do 150 with a fuel pump upgrade. Dave |
if your timing is way up there with the tune back it down a few degrees. also check into running some ngk tr6 plugs. they aren't as hot. a 100 shot all day long will be ok with a few safety precautions.
Right now I have Denso Irridiums... But if NGK is better... Ill get em.. Yeah I heard it was a good system... Ill do what yall tell me... And Ill post up new track times...
The Denso Irridiums are a good plug for nitrous use. What heat range do you have (if you don't know, just give me the part number)? You might have to re-gap them though.
Matt |
The pt #5325
Yea unfortunatley those are only a Denso 16 heat range. Its comparable to a NGK TR55. I would pull them out and run a set of colder plugs. Here's a list of what I would go with:
NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326) The NGK TR6IX is an iridum plug as well as the Denso IT-20. The iridiums always find their way into the shop truck due to their great idle quality but unfortunatley they're very expensive. If you're on a tight budget, the TR6's or the 103's will work just fine! :cheers: Matt |
Wow!!! Holy Shit!!!! I hooked up the nitrous with just a 75 shot... And I get sideways at 60... Just need the new plugs and then ima see what the 125 will do...
sideways at 60????? how wet were the roads LOL.... you must be running like 225 tires on that thing...LOL....
i am spraying a 125 shot and at 60 it plants and goes. hell, i spray at 55 since i have 4.10 gears and it still just goes. if you are sideways with a 75 you have something wrong, bald tires, skinny tires or wrong jets.
