Compilation of my turbo truck over the last 9 months
A little vid of my truck, some ups and downs over the last 9 months.
Cool video, I remember the wreck. The truck turned out awesome, keep at it.
(Post 5303205)
Truck looks beastly on the M&Hs. If I was still on stock rear brake setup I would be tempted to try the 17" 390s
Originally Posted by GMCtrk
(Post 5303209)
Awesome vid! I'm taking notes from your build and hoping to do a similar setup
Originally Posted by echoman
(Post 5303253)
Originally Posted by fastjweb
(Post 5303254)
Thanks, pretty simple set up, stock 4.8, scoggin dickeys HT1 cam, BTR dual valve springs, stock pushrods, 60lb plug and play injectors, racetronix drop in pump with hot wire kit, 3.90 gears, trutrac, built 60e with ptc converter, caltracs, stock shocks, drop shackes, and add a leaf removed. Trick kit with a 70mm master power at roughly 11psi, 3" down pipe into 4" MBRP exhuast, no cut out, no meth yet. And it has efans. With this converter, truck drives stock, goes down the road at 60 under 1400 rpm, and averages 24 mpg.
Which brand of injectors?
Cool video!! I have always liked your truck and this video is great. You are really close to even better times.
It's good now. It'll be great soon. I love you're abulirt to stick with it!! |
