Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Oil pressure /sender question
Old 05-02-2018, 10:49 AM
loose nutt's Avatar
Default Oil pressure /sender question
I have a 2000 Chevy Silverado Z71 with the engine from a 2004 Tahoe 5.3 I just replace the oil pressure sensor ACDelco part #12677836. I made sure it was tightened down the spec and the connector was on firmly and I am getting no reading from it. I noticed from the ACDelco website that from 99 to 2002 is a bit different from 2003 to 2006. My question is, is there something with the 2000 that won't read this sensor for a 04? Or did I just get a bad sensor
Old 05-02-2018, 10:56 AM
Custm2500's Rude Friend
1FastBrick's Avatar
yes the 99 - 02 sensor is different and utilizes a different plug.
Voltage range might also be different.
Old 05-02-2018, 11:46 AM
loose nutt's Avatar
Are they threaded the same? Will the one for the 2000 work on a 2004 engine?
Old 05-02-2018, 12:05 PM
I have a gauge for that
Atomic's Avatar
They are completely different. The 99-02 is tall, 1 wire, resistance based. The 03+ is 3 wire, short, and voltage based. The plugs are different also.
Old 05-02-2018, 03:32 PM
1FastBrick's Avatar
Despite the difference, The thread size did not change on the block though.
Old 05-02-2018, 08:36 PM
loose nutt's Avatar
am I glad to hear that. Otherwise I would have to rethread my block LOL
charcold-bowtie
08-04-2011 07:08 PM
adam1803
10-01-2006 10:10 PM
99Silver6.0
09-07-2005 11:21 AM
eallanboggs
08-23-2003 07:43 PM
Quick Reply: Oil pressure /sender question
