What gaskets needed for cam swap?
I just got my ultra torque cam for vinci this morning
Been buying everything in pieces Just have lifters and gaskets to buy Is there a "cheaper" better route than the ls7 lifters? I plan on getting cometic gaskets .04 thickness give me roughly .25 jump in compression. What is yall's opinion on this? What other gaskets are a must? |
1 Attachment(s)
How many miles on the engine? You dont have to remove the heads for a cam swap. Im still running the stock lifters. For gaskets:
water pumpx2, timing cover, timing cover seal, new crank bolt, for heads, head gaskets, and new gm bolts. I would look into getting the ls2 timing chain. cheap and alot stronger than stock bottom is LS2 Attachment 132827 |
150,000 miles so lifters are a must! If I go with the ls2 timing chain are you saying I have to get a new timing cover along with he gasket/seals for the timing cover?
Originally Posted by tqcraver00
(Post 4963296)
Just had this done to mine recently. LS2 Chain https://dl.dropbox.com/u/20842657/PI...20%2835%29.JPG LS2 Cover https://dl.dropbox.com/u/20842657/PI...20%2832%29.JPG https://dl.dropbox.com/u/20842657/PI...20%2844%29.JPG |
I resued my stock cam gear. Works fine. Ive spun mine to 6900 a few times and its holding strong. may also want to inspect the oil pump while your there.
Originally Posted by ak2007r6
(Post 4963314)
:D
Just had this done to mine recently. |
I reused every gasket when I did my cam swap, if you cam is mild I would let the lifters alone. With the ls7 lifters you will need different length push rods than stock. Unless you are spinning it to the moon, a cam swap can be done pretty cheap, I spent no more than $400 dollars on mine
Originally Posted by Ferocity02
(Post 4964059)
Any more info on that black plastic piece in the middle of the chain?
First if all some info on what year the truck is would be awsome
If it is a gen 3 motor your do not change the front cover nor does the LS2 wedge get used for you. Gen 4 block there is a whole part list i did in the GMT900 section that breaks everything down to you. |
2000 5.3L
I believe gen 3 go in depth why the ls2 wont work |
| All times are GMT -5. The time now is 01:52 AM. |
