Welp it happened - 427ci lq9 ate it
Old 04-25-2017, 06:57 PM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
Ive seen a couple LS7s make it like 150mi on a dropped valve. anything is possible when you dont give a **** about the motor lol
Old 04-25-2017, 07:23 PM
darkirish63's Avatar
I've murder two LS7 lifters in my little 383 stroker...never again. Spent $ on Johnsons this time around.
Old 04-25-2017, 08:24 PM
Gadgetized's Avatar
What oil are you running? Did your machine shop suggest an oil to use? Sometimes they make the tolerances a little loose expecting you to use thicker oil without telling you to do so. Do a leak down test when you get back and see what is actually happening.
Old 04-26-2017, 11:21 AM
TrendSetter's Avatar
i just had my bypass in my oil pump stick open after my comp trunion kit filled the motor with metal. oil pressure just dropped off for no reason.
Old 04-26-2017, 06:59 PM
Now that's odd. Bearings disintegrate or what?
Old 04-26-2017, 08:33 PM
03sierraslt's Avatar
Comp trunnions kits have been failing left and right. The bearings eat up the trunnions.
Old 04-27-2017, 01:59 AM
8 Second Truck Club
Blown06's Avatar
**** man, just leak down 5 and see where you're at quick. Hopefully nothing big.
Old 04-27-2017, 09:29 AM
I run conventional ZR1 20W-50 (5qts) + 1 quart 50W and change it every 3k.
Old 04-27-2017, 09:30 AM
better check mine I guess while the motor is apart...****.
Old 04-27-2017, 10:16 AM
mine looked good and felt tight but when i pushed one of the bearings back out you can see the trunion is eaten away. only two of the surfaces werent ruined. my whole motor had a fine dust of hardened steel in it. the bearings had a bunch of it embedded in them, the bypass piston was all scratched up causing it to stick in the bore, its bad stuff.
