valvespring comprossor tool
Old Nov 21, 2008 | 01:35 PM
Go5.3tt06's Avatar
Default valvespring comprossor tool
How much did you spend $ those tool? I want look a cheaper one to buy.
Old Nov 21, 2008 | 02:04 PM
Hawk179's Avatar
So many people make them. 25 bucks all the way to 200. Depends on what you find and how you want to use the tool.
Rick
Old Nov 21, 2008 | 03:27 PM
L7 Sierra's Avatar
A cheap ones are hard to use, and the expensive ones are that but easier to use. Other that they do the same job.
And my feelings are that if you race alot TI or at the very least tool steel retainers and locks are a must both companies you mentioned are very reputable. Also lower weigfht retainers and locks allow more valve control and free up a couple not a few horsepower. The XFI cams are pretty extreme in the lift department and lift kills lifters and valve springs so don't cheap up.
When I first started in hotrods .600 lift was race only. Now a days its not uncommon becouse the heads the average guy can afford can support those big cams too. So now our limiting factor is the valve springs and the pressure needed to take advantage of those big cams.
The old Duntov 30 30 was one hell of a cam for its day, but its lift was less then .485" lift, 254* duration @ .050 which adds up to about 300 duration at normal specs. They used cams such as this becouse the springs of there day .500 lift was extreme. We just happen to hit the same problem again.
Old Nov 21, 2008 | 04:23 PM
Main One's Avatar
When putting in dual springs, I'd wished I'd spent more.
Old Nov 22, 2008 | 09:59 AM
banker099's Avatar
made my own...works well for dual springs too...ill post a pic up later if yall want
Old Nov 28, 2008 | 09:15 PM
eallanboggs's Avatar
There is only one tool worth spending your money on for the LS series spring swap bar none. It's the Vinci/Crane for $100. It does two valves at a time. None of the others do that. It's a real time saver. It pays for itself on the first use.
Old Nov 28, 2008 | 09:16 PM
03sierraslt's Avatar
I have the Crane Spring tool also... Worth it IMO.
Old Nov 28, 2008 | 09:52 PM
Go5.3tt06's Avatar
Well. I dont have much supply to make one. I want to know which one I can buy fair price. Since I check thunderracing.com They cost a little higher.
Old Nov 28, 2008 | 09:53 PM
Go5.3tt06's Avatar
You say Vinci carry that tool for $100. Im alittle confused.
Old Nov 29, 2008 | 02:16 AM
454navyss's Avatar
check with summit. i looked today, around $45 for a tool to change springs without taking the heads off
