-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Tuning with new cam? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/tuning-new-cam-470104/)
a.vinson Oct 3, 2010 11:05 AM
I got an 04 5.3 silverado and im looking to put a comp cam xfi extreme cam in this next weekend. It also says i will need a programmer for the cam, but i already have a vortech supercharger on with tune so i was wondering if i will have to do much tuning after i intall the cam?
Avalanche2002 Oct 3, 2010 11:43 AM
First, to give you a definitive answer, you should post the specs for the cam.
But the answer is yes, especially on the idle tuning. For sure fueling at the higher rpms will also need to be adjusted.
ByuTrukr Oct 3, 2010 05:47 PM
oh yeah u will definitely need some tuning
OnyxSilveradoSS Oct 5, 2010 11:22 AM
vote for tuning here.
02'Z71ONDUBZ' Oct 5, 2010 12:38 PM
If you want to get the best results and ensure that your engine is running safely then retune for the cam.
a.vinson Oct 17, 2010 10:47 PM
Got the cam in i noticed major power gains, and my afr hasnt changed even at high rpms. I recommend that if any one puts comp cam ultra gold rocker arms with a 1:7:2 ratio in a ls1 that they get valve cover spacers or different valve covers cause they will hit the stock valve covers.
