Torque specs for arp head bolts???
Can someone tell me what they are?I'm trying to get my truck back together right now and I cant find my info I had before.Are they the same as the ARP head studs? 30,50,70 Thanks for your time.Mike
yes max torque is 75 for the big bolts and 25 for the little ones as far as the torque seqence look around on here or if you have a haynes manual it will tell you thats how i figured mine out pretty sure you can look up the manual online
That's very important to note...my father told me a long time ago how he uses different torque specs on bolts depending on which lube he uses on them, and it makes a difference for sure.
