-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Those with ARP head bolts (https://www.performancetrucks.net/forums/internal-engine-modifications-158/those-arp-head-bolts-502902/)
BigV8 Jun 5, 2012 05:41 PM
On my 99 5.3, the factory call for loctite on the oem smaller top bolts, I'm using ARP and their directions don't call for any. Do you skip the loctite and just use the grease? Thanks
TA63 Jun 11, 2012 10:47 PM
Yes. Use the moly lube that comes with the bolts.
dmelvin Jun 12, 2012 09:05 AM
This. I've run my APRs for about 12,000 miles with no leaks and no locktite. I also overtorqued my long bolts 3-5 ft/lbs, but this isn't necessary.
Preston129 Jun 12, 2012 12:22 PM
Another vote for just their assembly lube. Proper torquing is better than thread sealing IMO.
1BadAction Jun 12, 2012 12:22 PM
I sure wish they would give a little more lube in their packages, what they come with isn't enough to coat the end of my... well nevermind, but it's not hard to use it all on one side, lol. At least with a big block.
Sales3@Texas-Speed Jun 13, 2012 08:58 AM
Run the moly lube, but I would only recommend tightening to their spec. Although, we coat the threads and underneath the head of the bolt to ensure correct torque.
