<TECH ONLY> Stock cam specs
This is a constant question, and one that is very hard to answer (since I don't know :jest: ).
So please post up what you *KNOW* to be true. Please guys, no guess work... 4.8L cam? 5.3L cam? 5.3L HO cam? 5.7L (LS1) cam? 6.0L cam (same cam between both LQ9 and LQ4)? LS6 cam? LS2 cam? Thanks |
LM7 Left - L33 Right
Both are 2005 Compression Ratio 9.49:1 9.9:1 Camshaft Lobe Lift - Exhaust 6.96 mm 7.2 mm 0.274 in 0.283 in Camshaft Lobe Lift - Intake 6.82 mm 7.2 mm 0.268 in 0.283 in Valves - Valve Lift - Intake Valves 11.58 mm 12.24 mm 0.456 in 0.482 in Valves - Valve Lift - Exhaust Valves 11.82 mm 12.24 mm 0.465 in 0.482 in 114LSA 2000 and up 115.5 LSA 1999 |
Barrowed off of LS1tech.
http://ourworld.cs.com/jrp98ls1/cam+spec+1.jpg |
Corvette LS1
97-98 12554710 199/207 .472/.479 117 98-99 12560964 199/207 .472/.479 117 2000 12560968 198/209 .500/.500 115.5 01-03 12561721 198/207 .467/.479 116 Corvette LS6 2001 12560950 204/211 .525/.525 116 385hp 02-04 12565308 204/218 .555/.551 117.5 405hp Camaro/Firebird 98 12557812 198/209 .500/.500 119.5 99-00 12560965 198/209 .500/.500 119.5 01-02 12561721 196/207 .467/.479 116 Trucks and SUV with Vortec engine LR4 and LM7 99 12560966 191/190 .457/.466 115.5 00-04 12560967 191/190 .457/.466 114 the 03-04 LM7 used the 12560967 camshaft LQ4 99-00 12560967 191/190 .457/.466 114 01-04 12561721 196/207 .467/.479 116 01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam LQ9 02-03 12561721 196/207 .467/.470 116 GM Performance Parts Hot 12480033 219/228 .525/.525 112 ASA 12480110 226/236 .525/.525 110 |
Interesting fact, same size cam in the 5.7 and 6.0, and the LS1 makes peak power 400 rpm higher than the 6.0.
(Post 4151875)
Corvette LS1
01-03 12561721 198/207 .467/.479 116 Camaro/Firebird 01-02 12561721 196/207 .467/.479 116 LQ4 01-04 12561721 196/207 .467/.479 116 01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam LQ9 02-03 12561721 196/207 .467/.470 116 |
Considering its the same PN id say its a typo...
looked up the PN.. 196/201 .467/479 116 haha conflicting info.. :nono: 12561721 LQ9: 2002-2006 I: 196 I: 467 116 Stock cam for 2002-2006 LQ9 and 2001-2004 LS1 engines. LS1: 2001-2004 E: 201 E: 479 '99-'00 LQ4, 191/190 .457/.466 114 PN 12560967 '01-'06 LQ4, 196/207 .467/.479 116 PN 12561721 GMPP Hot Cam 219/228 .525/.525 112 PN 12480033 |
Originally Posted by GMCtrk
(Post 4151880)
(Post 4151875)
LQ4
99-00 12560967 191/190 .457/.466 114 01-04 12561721 196/207 .467/.479 116 01-04 LQ4 cam is same as Camaro, Corvette LS1 and LQ9 cam LQ9 02-03 12561721 196/207 .467/.470 116 |
(Post 4151875)
LR4 and LM7 00-04 12560967 191/190 .457/.466 114 |
