<TECH ONLY> GM Head Casting Info
Old May 8, 2010 | 02:15 PM
skolman91's Avatar
The cars get all the parts first then the trucks. I believe 03 on the vettes possibly some late 02 vettes
ook... that didnt really answer what i was asking, must of worded it wrong. your listing them as 05-up truck heads, and started appearing on trucks in 05. That would be nbs and i thought they started using them on the ly5 and 07(nnbs)up trucks..?
Old May 8, 2010 | 08:44 PM
1FastBrick's Avatar
Custm2500's Rude Friend
my sister had an 05 tahoe with the 799/243 castings on them. all the info I gathered was from this site and others. I just tried to put it all together for everyone to use.
Old May 8, 2010 | 09:18 PM
skolman91's Avatar
interesting, never herd that before. I was just trying to say wording it like that makes it sound like since 05 they have been standard on 5.3s, and thought that started in 07 on 5.3s from what ive read on here.. but thanks for posting up the info, your other info threads have helped me out in the past.
Old May 8, 2010 | 09:48 PM
fastnblu's Avatar
Here is what I have found. I tweaked it a little with help from others like trever1t
https://ls1tech.com/forums/new-ls...casting-s.html
http://web.camaross.com/forums/showthread.php?t=410492
ALL Gen III heads are interchangable. How ever, They need to be matched up with the proper engine combo to see any gains.
Here is a list of a known production casting #'s:
933 97 aluminum perimeter bolt 5.7
806 97-98 aluminum perimeter bolt 5.7
853 99-00 aluminum center bolt 5.7
241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings)
243 04 up LS6 aluminum center bolt 5.7 ***These castings were also used around 05 in truck applications***
862 99 and up 4.8-5.3 Truck heads
706 99 and up 4.8-5.3 Truck heads
799 05 and up 4.8-5.3Truck heads ***reportedly came on a few corvette's too*** These are basically 243 Heads
873 99-00 LQ4 6.0 Iron center bolt heads
317 01 and up LQ4 and LQ9 6.0 aluminum center bolt heads
035 01 - 04 LQ9 6.0 aluminum center bolt heads
Even more detailed info:
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
What you need to know:
The standard issue LS1 heads is best all-around head for the street / strip engines . A thorough porting and millimg job plus a valve upgrade on these will really wake up your engine.The heads have undergone only minor revisions since their introduction in 1997 , most notably a switch from perimeter to center valvcover bolt configuration for the 1999 model year. Each style has its own dedicated valvecovers and coilpacks mounting apparatus.
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
The LS6 cylinder heads is essentially a tuned-up version of the LS1 head. At 65cc, the combustion chamber is slightly smaller and more efficient than the LS1. The more efficient design shortens burn times and ultimately means less ignition timing advance is required to produce the same power. And because less timing allows more efficient combustion, the Ls6 heads allow the engine to produce more torque. The exhaust port is a unique D-shape that improves flow. LS6 heads are the best choice only when all-out power is needed. Be prepared for a big price tag at the dealer or steep core charge from your head porter.
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
Casting Number 873
Head: 1999-2000 LQ4 6.0 Liter Truck
Material: ***Cast Iron***
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Chamber 71.06cc----0.100---0.200--0.300--0.400--0.500--0.550--0.600
Intake 210cc-----------66-----142-----196---228----236---238-----240
Exhaust 75cc----------59-----104-----137---155----167---173-----177
The LQ4 head received aluminum heads starting in models year 2001. All other features are the same as previous years iron heads. This is the workhorse head for street / strip turbo and blower cars. They offer a large combustion chamber that lowers compression ratio making them perfect for a forced induction application. Swapping on the LQ4 head drops the compression ratio of a typical LS1 engine to 9:5.1
The Cast-iron casting are heavy!
So you want to figure out how much to mill:
It takes about .005" milling of the block deck to remove 1cc of volume. It takes .007" milling to remove 1cc from an LS1 head
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mill a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
241 cast heads were Die Cast which is a process that smooths up the ports a bit compared to the Sand Cast procedure that was done on the 806 and 853 heads. Once ported any "advantage" the 241 cast had is moot.
Same Info applies to the:
4.8L/5.3L Truck 862 and 706 Head castings
While the 706 Heads are a SPM = Semi Permanent-mold And considerd to be a more consistant head casting then the 862 wich are Sand cast, Once ported There Is no difference.
799 Vs. 243 Info Copied From pillboxesghost Post's in ths thread https://ls1tech.com/forums/conver...l#post10241473
This appears to be one of the common misconceptions about heads having the 243 casting no. -- they are not necessarily LS6 head assemblies. The LS2 heads (243 or 799 casting) have the "heavy" standard LS1 valves. However, they do have the LS6 springs.
Only the true LS6 engine heads have stainless steel (not titanium) hollow stem valves (the exhaust stems are sodium filled). These valves are slightly longer than LS1 valves too.
The LS7 heads do have titanium valves.
New LS2 heads are about half the price of new LS6 heads (check sdparts.com). GM is "really proud" of those hollow stem valves!
Oh, if you have the 799 castings -- the only thing "Corvette" about them is the valve springs/retainers! Still a desirable set of LS1 heads though!
Supposedly, the 243 mold was done at GM Research, the 799 mold furnished to other vendors. The same vendor may have the 243 and 799 mold.
Both heads have identical sized intake and exhaust valves
I highlighted some of more pertinent things, at least to me, if I ever wanna find it quick. . What stood out & always wondered bout this is..."Once ported, there is no difference. Once ported any "advantage" the 241 cast had is moot."
Finally, I see for myself, an answer. Thanks.
...all the info I gathered was from this site and others. I just tried to put it all together for everyone to use.
Thanks for doin this. I hope if I ever need this info, I'll remember this thread. My hat's off to you. And others.
Old May 8, 2010 | 10:02 PM
budhayes3's Avatar
PT's Slowest Truck
Excellent...very helpful for sure
Old May 9, 2010 | 09:25 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yep -- awesome info!! <Tech only> bound!!
Old May 9, 2010 | 11:50 AM
1FastBrick's Avatar
Ask Bill. I thought he was supposed to stickey it some were.
Old May 9, 2010 | 10:35 PM
TXoldskool's Avatar
so is this thread for genIII only? no info on the genIV rectangular port heads?
Old May 10, 2010 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
Seems that way so far...
Old May 10, 2010 | 03:44 PM
1FastBrick's Avatar
If you guys have that info feel free to post it up!!! when I wrote this, thats all I was able to find and confirm.
