still low oil pressure after o ring swap?
Old May 3, 2010 | 01:29 PM
Hawk179's Avatar
Stop messing with a stock pump, use the GM DOD pump out of the later year trucks, then tell me you dont have crazy pressure.
R
fastrt's Avatar
11 Second Truck Club
get you a high pressure pump. 20 is ok at idle. I like to see 25-30 min, but thats just me. that cam bearing could be where you are loosing psi, or cam plate gasket. i have seen some old cam plate gaskets leak and loose pressure.
Old May 3, 2010 | 01:32 PM
Hawk179's Avatar
Also, if you have a cam bearing that looks bad, it could have walked. If it did, you gota pull the motor.
R
Old May 3, 2010 | 03:46 PM
to have a machine shop put the cam bearings does it have to be a bare block? or can it be with the cam out and holding the lifters in there place.
Also after taking a oil pan off another 6.0 i have, i noticed a small gasket that goes on top of the oil pan gasket right above the oil filter and it has 2 holes. I dont remember putting this gasket on the 6.0 on my truck could this be an issue?
Old May 3, 2010 | 08:03 PM
TIM Z's Avatar
11 sec. Truck Mod
Worth a try, i vaguely remember that gasket when i had the oil pan off my LQ4, I swapped the fitting off my 5.3 that had no oil cooler openings.
Old May 3, 2010 | 09:29 PM
mike the crock's Avatar
had a similar problem with my lq4 but mine would drop to 0 changed pump,then changed o ring still same problem ,well my brother came up with mabey the motor was dirty in the inside and it might be pluging up the filter so we did like three oil changes right back to back and the oil was coming out dirty after the oil changes it would still do it but it would last longer so he decided that every time the oil presure droped we would change the oil filter well we chaned it about 3 times a week its been about 1 month since the last time i changed it and my oil presure has been fine
Old May 3, 2010 | 09:44 PM
budhayes3's Avatar
PT's Slowest Truck
I remember an old thread where a member here forgot that gasket and didn't get any oil flow up to the heads....IIRC
Old May 4, 2010 | 10:50 AM
04BlackSilverado's Avatar
So i drained out the oil and it came out a little dirty
Did you clean out the oil passages prior to assembly? Sea Foam the oil to clean out your system. Do a search on how.
I had a friend check the rod bearings and clearances and they all look good.. All the cam bearings looked good but the rear one looked a little worn out but went and put the cam in anyways.
How did he check them? Did he remove the caps and measure or just do a some sort of visual?
Bad cam bearing will definitely cause this issue as well.
so would I be ok upping the boost to around 9-10 lbs and still live a normal life??
I wouldn't even run 5lbs of boost until you got it figured out.
Also after taking a oil pan off another 6.0 I have, I noticed a small gasket that goes on top of the oil pan gasket right above the oil filter and it has 2 holes. I don’t remember putting this gasket on the 6.0 on my truck could this be an issue?
Yes, this could be another issue as well.
Each of these issues by themselves may not be a problem, but after putting them all together it makes one bigger problem.
Bottom line, I would take it out, and go through it 100%.
If you really want to run 10lbs of boost, I would have all bearings replaced, and have the block looked over by a machine shop.
Sorry, and good luck.
Old May 4, 2010 | 02:00 PM
MikeGyver's Avatar
Originally Posted by 04BlackSilverado
... If you really want to run 10lbs of boost, I would have all bearings replaced, and have the block looked over by a machine shop. ...
Same here. Those pressures are lower than mine were with two wiped out main bearings.
Old May 4, 2010 | 05:40 PM
I didn't clean them but looked cleaned.. will try the seafoam just in case. My friend removed the caps did a visual inspection on the bearings and used plastic gauge to check the clearences then re-torqued them down again.. going to try changing the oil too and the oil pan gasket. if worse imma have to pull the engine out
