Push Rod Diameter
Old Apr 10, 2013 | 07:37 PM
lycominghunter's Avatar
Default Push Rod Diameter
I've been searching and I can't find the answer. I am doing some supporting mods in preparation for a turbo on my 2003 4.8 with the 862 heads and I'm looking for some hardened pushrods, but I'm not sure what diameter pushrods to go with; 5/16" or 3/8". I almost pulled the valve covers off to see if I could measure them today but I figured I'd see if anyone on here knew first. Thanks for the help!
Old Apr 10, 2013 | 08:28 PM
Atomic's Avatar
I have a gauge for that
Stock ones are 5/16...you want the biggest ones you can find in the length you need. The added weight is well worth it. I have the comp 3/8" pushrods.
Old Apr 10, 2013 | 08:57 PM
UnVmy5.3's Avatar
I was looking threw summit and i seen 5/16 push rods that were 7.400 then right under it seen ls push rods that were more expensive. Whats the difference
Old Apr 10, 2013 | 09:31 PM
ok, sweet. Thanks atomic. So those 3/8's aren't going to have any trouble fitting? They'll drop right in and I won't have to change anything to use them?
Old Apr 10, 2013 | 10:58 PM
Atomic's Avatar
Mine were just drop in...might want to measure your pushrod holes just to be certain
Old Apr 11, 2013 | 12:24 AM
TXsilverado's Avatar
you can go with a like I did
Old Apr 11, 2013 | 05:58 AM
Yea best way would be to measure. Thanks for the help Gents!
Texas5.3_1251
Mar 5, 2016 08:10 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
