-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Project (https://www.performancetrucks.net/forums/internal-engine-modifications-158/project-400087/)
ONLYA4.8L Aug 29, 2007 05:27 PM
Project
Doin a iron 5.7l from a 4.8l block.. So need to make a shopping list.. So far usin stock ls1 crank.. rods and pistons.. Need help with the rest.. I want to try for at least 400rwhp..
jkade72 Aug 29, 2007 07:07 PM
My motor is still at the machine shop but I am doing the same thing. Are you going to use the stock heads and truck intake? Give us specs of what you are going to do to the motor ( heads, cam, intake, etc)
OLD BULL Aug 29, 2007 07:32 PM
I know your doing a 5.7l but this thread might help you a little.
https://www.performancetrucks.net/fo...d.php?t=398140
PappyDan Aug 30, 2007 02:09 AM
well we already know that with a few gm parts
you can have 405 at the crank on that 5.7.
some here have their 5.3's pushing 330 to 335 hp at the rear NA.
do some of the same as they did should have you close to
around 380 to 385 at the rear maybe a little more.
ONLYA4.8L Aug 30, 2007 03:16 PM
Nice.. Honestly.. Im tired of those rice queers and there damn turbo 4's runnin their mouths.. Just want something that will make em think twice.. I want a low 12sec possibly high 11 n/a truck.. Its not my dd but want to be able to crusie with my buddies every once in a while.. MPG dont matter.. I got my 96 sentra for that.. Gonna go with the truck intake.. stock heads gettin ported and milled.. Stayin with them for now
Thunder Racing Custom Camshaft
"227 xTReme" - 227/227 .639/.639 116 LSA. 2200-6800 RPM If it will work with that set up.. thinkin 3200 to 3500 stall back to 4.10s in the rear..
PappyDan Aug 31, 2007 02:07 AM
i'm going to help you out here a little bit.
here are two books i think should help you
reach your goal.
the info in these books are like gold, use it wisely.
http://cgi.ebay.com/ebaymotors/How-to-Build-High-Performance-Chevy-LS1-LS6-Engines_W0QQitemZ180154685134QQihZ008QQcategoryZ33 615QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Dyno-Proven-GM-LS1-LS2-LS6-LS7-Performance-Parts_W0QQitemZ180154694096QQihZ008QQcategoryZ3361 5QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
