-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   pickup tube oring? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/pickup-tube-oring-480837/)
GetBlown01 Apr 10, 2011 06:47 PM
pickup tube oring?
as most of you know, ive been having an oil pressure issue on my freshly rebuilt 6.0. so i took off the pan to look at the o ring. lowered it down and pulled the oring off and it was black. i thought it was supposed to be either red or blue? the engine is an 06 lq9. the oring looked fine, and i noticed that the pickup tube where the oring sits on it has a red strip going around, i guess to let you know that it is supposed to be a red oring. it wasnt pinched or anything, i just want to make sure whats supposed to be there before i put it back together. any help is greatly appreciated
bennettracing Apr 10, 2011 07:25 PM
When I took my LQ4 apart the O-ring I removed was red, the melling oil pump I purchased came with a black and a green. The black O-ring was too thin and the green matched the red o-ring so I used the green from melling nice tight fit I haven't fired it up yet but I'm sure its correct, hope this helps.
smokeshow Apr 10, 2011 08:26 PM
Why not swap it out? If the pan is already down, it won't cost much to replace the o-ring if you think that could be the problem. Cheap way to rule out a possible issue.
08cheyennesc Apr 10, 2011 08:56 PM
Just replace it with a red oring , you already remove the pick up tube so it will need a new oring everytime the seal is broken. GM 12584922. Get from SDPC >>>
GetBlown01 Apr 10, 2011 09:35 PM
Yea I'm going to swap it out anyways , Im just hoping this is my problem. I took it off and measured the thickness if it, and it only came out to a lil over 3mm. The red one is is 4.20 mm.so I'm going to get it tommorow and pray that's it.
Daryn Apr 10, 2011 11:49 PM
whenever you take the o ring out ,if its still in perfect conditon( no pinches).. dont throw it away, it regains its original shape within a day or so - ya never know, just incase your in a bind and cant find the right o ring
GetBlown01 Apr 11, 2011 09:06 AM
I didn't throw it away. I wanted to wait a day or so and measure the thickness to compare it to the new one. Im thinking the builder just put the wrong one in there
budhayes3 Apr 11, 2011 10:23 AM
Yep, a lot of guys have reported this issue when using a black or blue o-ring...can't really blame the builder as that's the part/part number that these oil pumps call for. Personally, I only know that the red o-ring is the one that works from people's troubles on this web site, as it isn't common knowledge. I wish that someone would let GM in on the big secret, so they can change their catalogs and delete the problem o-rings :nod:
fastnblu Apr 11, 2011 11:20 AM
I really should write that p/n down just to have. When I did my cam & chain, I bought a new one. Had the window down & didn't realize it blew outta my pocket. :disgust:
I retraced my steps & looked by roadside. Akin to finding a feather on a stretch of road, near impossible. So I had to go order another, & they wouldn't do it w/o cash in hand. What a hassle. :bang:
It took 2 days to get replacement o-ring #2, adding more time to the job than already. Lesson learned: just cause u think u have somethin stuffed in your pocket, when u really need it under these conditions, it won't be there. :lol:
:hmmm: I never thought of that (measuring), I only knew of the different colors ; but that makes sense too know that I think about it, cause they have to differ somehow. I just knew the right people on PT & they saved me the some grief. Told me there were red, blue & blk. For some reason I thought my orig. was red w/. a green stripe or the other way around. I got the red.
I was unaware they'd regain their shape after 1 day or so. :thumb:
I think I kept my old one for those JIC instances. ;)
GetBlown01 Apr 12, 2011 01:52 AM
So I picked up the red oring, big difference in thickness! Installed it, made sure everything was good,then I put oil in it ,unhooked the spark plugs and turn the engine over a couple of times. Still no pressure. Do you guys think I need to let it fire and run for a few seconds? I know that when you start a truck it takes a second or to before it comes up. Just wondering if turning it over without spark will build enough pressure or not
