Part list for cam swap. Input Please!!!
Old Oct 27, 2012 | 05:45 PM
Camin00's Avatar
Default Part list for cam swap. Input Please!!!
Hey dudes a buddy told me about this site so i joined. I am a bare foot water skier, so I tow a 4000lbs boat every weekend.
I just bought a comp 212/218 114 lsa low lift for more performance and towing.
Already have 7.4 push rods from the rocker swap
Now I need all the other parts
My list
sdpc
LS2 timing chain $80
ws6 store
Ls7 lifters with ls2 trays, $160
Lunati dual valve spring set .660 lift $240
graphite head gaskets $50
ls6 oil pump & O ring $110
ebay
Pro comp head studs $70
ARP balancer bolt $30
Old Oct 27, 2012 | 07:08 PM
Chevy_King1500's Avatar
I would suggest checking your PR length when installing the LS7 lifters, you may need 7.350 PR's
Any reason for getting the dual springs? Ls6 spring are $60 and will work great with that cam
Head studs? plan on boost?
Old Oct 27, 2012 | 08:10 PM
Camin00's Avatar
For the head studs... my mind set was if I need to take the motor apart again for some reason I wont have to buy new gm bolts every time. Just get the head studs and be prepared for any future upgrades. Arp headbolts/studs are to expensive.
Everywhere I read the Ls7 lifters are the stock replacement. Are they longer?
For the springs the truck has 100,000+ miles so I was looking for a spring kit with new seals, locks, retainers..... and when the transmission blows and gets rebuilt I plan on putting a 2600 stall in it, possibly a larger cam with more lift/ ported heads. Wayyyyy down the road
Could you explain the lifter push rod thing just a little bit more?
What brand lubes would you recommend for the cam/bolts?
Can I get by with head gaskets and o ring or is other gaskets needed?
Old Oct 31, 2012 | 02:17 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
The LS7 lifters are not longer, however they do have a different plunger depth, which is why you will want to measure. We typically shoot for somewhere around .050"-.060" preload.
Old Oct 31, 2012 | 02:27 PM
Ferocity02's Avatar
I had to use 7.350" pushrods with the LS7 lifters. If you have the funds, buy a set of 7.350" rods and maybe 7.375" rods, and a length checker. Then sell the rods you don't end up using. Otherwise you will have to wait for the pushrods to show up once you figure out the right length.
Also consider getting a new timing cover gasket and water pump gaskets.
I think those springs are overkill unless you're planning boost. What is the lift exactly? I have new takeoff valve seals if you're interested. You can reuse the retainers and locks.
Old Oct 31, 2012 | 03:13 PM
dirt track racer 81's Avatar
Balancer install tool from Scoggin dickey
Old Oct 31, 2012 | 03:46 PM
^ Yup that thing works great!
and a dual spring compression helps too..
chopperloco
Jul 10, 2016 10:45 PM
iregret
Jul 27, 2015 10:32 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
