Odd oil pressure
Odd oil pressure
Curious what everyones opinion is ....
500 miles on rebuilt lq4, ported and shimmed oil pump, delete bypass in pan, new oil pressure sensor, new oring (double checked after assembly to make sure it wasnt pinched). Before rebuild the oil pressure was 20psi idle, 40psi WOT. Now it's 50psi idle, and stays 50psi at WOT according to factory gauge. I haven't put a mechanical gauge on it to confirm readings yet. Plan to do this weekend.
What would cause it to stay 50psi regardless of rpm?
The spring for the bypass opens at 50psi ? Can I get to the spring by dropping the pan? I cant remember.
You rebuild the motor, your clearances are tighter needing less oil volume, the oil pump is ported so it's flowing more. So it always out flowing what the motor can uses at idle and at speed. It's just alway in some form of bypass witch is 50psi. I don't think there is anything wrong with it.
Threw 2 different mechanical gauges on it, an Autometer and this no-name gauge both registered the same. Looks like warm idle is roughly 35psi, at 15seconds in the video at 5000rpms it hits 75psi at the fitting by oil filter on the pan. So I can only imagine the oil pressure sensor is bad or the gauge cluster. Anyway of testing the cluster or sensor ?
Justhereforinfo
32
05-30-2018 05:24 PM
thunder550
10-01-2006 06:08 PM
1slow01Z71
22
09-15-2005 09:23 AM
ranwalk
01-08-2005 09:13 PM
