new hci setup need some input
Old May 21, 2014 | 06:11 PM
lukn4trbl355's Avatar
Default new hci setup need some input
my heads have already been selected for my 4.8 build, as for intake manifold i plan on selling my tbss and was originally going to go holley hi ram. i now work for quartermaster which is a branch of comp cams and was told that i get parts for x% above cost. i will be swapping out my cam for a custom grind and was also told that i can purchase the fast lsxrt for around 400 or so...long story short this changed my input on everything. with the cam specs ill probably be turning 7k-7200rpm vs the 6800 im spinning now. my question comes down to is which intake would be the better one? and also which one would work better with nitrous?
thanks in advance
T.J.
Old May 24, 2014 | 03:16 PM
low2001gmc's Avatar
With 4.8 id stick with tbss. Holley is for bigger cube and dont shine til high rpms in 6.0s and above, so in a 4.8 forget it. Fast is too much in 4.8 also.
Old May 24, 2014 | 06:05 PM
correct me if im wrong but im pretty sure a member here did a dyno test of the fast lsxrt on his 5.3 and picked up just about 20rwhp at 6k on a stock nnbs?
Old May 26, 2014 | 04:30 AM
low2001gmc's Avatar
THere is a difference in cubes between a 4.8 and 5.3 and mostly everybody has idle issues with a fast truck intake.
lucas287
31
Jan 12, 2021 06:18 AM
simman22
Jan 21, 2017 10:27 PM
Blwn99x
Sep 11, 2015 09:27 PM
PDPERFORMANCE
Sep 8, 2015 11:01 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
