needs directions on my engine build
Old Oct 26, 2013 | 08:59 PM
Chevy_King1500's Avatar
Originally Posted by Noah Burns
heads on the 4.8 will swap on to a 6.0...
they will, compression will be a bit high for what I would recommend for FI
Old Oct 26, 2013 | 09:09 PM
Noah Burns's Avatar
what does it come out to with 5.3 heads on a 6.0? It's been so long since I did that math I can't remember. I ran some sweet p&p 6.0 heads on my 4.8 rcsp with a 224/228 it was a bad ****, would have been killer on boost...
Old Oct 26, 2013 | 09:16 PM
close to 12:1 I believe
6.0 heads would be great heads on 5.3/4.8 for serious boost
Old Oct 26, 2013 | 11:11 PM
chevy79's Avatar
Originally Posted by Chevy_King1500
Why not?
Everything on the 4.8 will swap over to the 6.0 besides heads only $500 for used 243's
4.8 and 5.3 don't make a lot of torque
I know all the accessories will be direct swap, but swapping a 6.0 and turbo will cost me more than just a turbo on my current engine. Above that, cam swap and the supporting parts along with it. Thanks for the help
Old Oct 26, 2013 | 11:13 PM
chevy79's Avatar
What was the hp and tq numbers with your setup?
Old Oct 26, 2013 | 11:20 PM
chevy79's Avatar
If I had to swap in a 6.0 what should I go with? Junk yard 6.0 or 0 miles rebuild short block or long block?
Thompson motor sport is making 370 lq9 and lq4 short, and long blocks with a verity of internals setups. Anybody have had them?
Old Oct 27, 2013 | 02:52 PM
roland1's Avatar
I just put in a Thompson motorsports 370 LQ9. Forged pistons and rods. I don't have many km's on it yet but so far so good.
Old Oct 27, 2013 | 02:54 PM
roland1's Avatar
My compression is 10.8:1 with 799 casting heads from my 5.3. Installed on my LQ9.
Old Oct 27, 2013 | 06:00 PM
chevy79's Avatar
What crank, pistons, and rods are used? Did you get it short or long block? Not many people in this forum are running them, most of threads I read here and there are recommending tsp blocks. What are your plans on this forged motor?
Old Oct 27, 2013 | 06:02 PM
chevy79's Avatar
Why did you choose to run 5.3s heads over 243, or ls3 heads? What cam do you have?
