need help with my cam change
hey i bought this cam:
Thunder Racing Custom Camshaft "TR 224-112" - 224/224 .563/.563 112 LSA 1700-6600 RPM Power Band. Excellent mid-range & high RPM power. Requires computer tuning on automatic transmission cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. but thats all i have, what spings do u recommend me, pushrods and what else?? i wont change heads, i dont wana take em off |
https://www.performancetrucks.net/fo...d.php?t=439843
im getting ready to put the same cam in my truck, see my thread for other needed parts ls1howto link below should help with your install aslo http://www.ls1howto.com/index.php?article=23 |
someone told me i have too change all this:
COMPCAMS LS1 VALVE SPRINGS LS1 VALVE STEM SEALS, EXHAUST LS1 VALVE STEM SEALS LS2 LIFTER GUIDE TRAY GM LS7 LIFTER SET of 16 GM LS1, 6, 2, GEN III TIMING CHAIN CAM & HEAD SWAP GASKET PACKAGE MELLING LS1 OIL PUMP when i change my cam is that true? or is pushrods, cam and springs enough if i dont take the heads off thanx |
you will need to change valve springs, i see no need for valve stem seals, nobody has been able to tell me the purpose of ls2 lifter trays, ls7 lifters are a good upgrade over stock, an ls2 timing set should be on your list, a cam and head swap gasket package is a must, and a ported ls6 oil pump is your best option
all of this is discussed in the thread i made that i linked above |
I'd grab some PAC 1218 valve springs and some hardened 7.4" pushrods, and new gaskets and coolant.
Just make sure you've got all the tools you'll need (a good spring compressor (Crane cams tool), all sockets and extentions, rent a chrysler harmonic balancer tool). Also, depending on your mileage, you might or might not need to change timing chain. Your stock oil pump will be fine, the reason some people say to change oil pumps is because in the early LS1 F-bodys, they had oil pump problems. |
if you are changing lifters/lifter trays you have to pull the heads man.
you dont need to do that for a simple cam swap. cam, PR's, springs and a few new gaskets if you want them... depends on how many miles are on your engine. i re-used all my o-ring type seals, but did the swap at 30K miles. you dont need all the other things you mentioned. |
I just read a post on another forum that the GM says the stock rockers are only good to .550. I know people are running them past that, but if you've ever seen them come apart, a set of adjustable rollers will seem cheap.
Originally Posted by TurboBerserker
(Post 4194572)
change out the springs and PR's You do not have to change the rest of it.. I have also heard that about the rockers, but have never seen a set break, somthing else usually does first..
(Post 4194572)
Could you direct me to that link? I'm curious to know the weak point in the stockers...Harland Sharp offers a trunion upgrade to the stockers that seems pretty cool |
