main bearing caps
Old May 10, 2011 | 11:33 AM
CodyBoy's Avatar
Default main bearing caps
Well I hope its right cause its together now.
Do not remember the orientation of the main caps. The rear was easy to figure out because the rear cover has to fit into the recesses.
The front and other three I faced the curved lip toward the rear.
But now the #s 1 2 3 4 are opposite the #5 rear cap.
Tried finding a pic online but no luck.
Found 1 pic in the Chilton manual and looks like #2and 3 are correct. Couldn't find pic of #1.
Any one have a pic of main caps installed less the windage tray?
Am ready to install the windage tray if all is correct.
Thanks.
Old May 10, 2011 | 11:41 AM
Sales2@Texas-speed's Avatar
Former Vendor
On the LSx engines that have the main caps with the "ears", #1-4 should all have the "ears" facing towards the rear of the block, while #5 faces forward.
Old May 10, 2011 | 11:42 AM
MARK3406E's Avatar
Make sure the bearing tabs are on the same side. That's the easiest way to tell.
Never min pic has been posted.
CodyBoy's Avatar
Found one pic(drawing) of it. http://ww2.justanswer.com/uploads/go...bearings_1.gif
The #3 thrust bearing says the 3 oil slots must face the rear. They do so I know that #3 and #5 are correct.
The pic showed #1 with the curved flange toward the rear which is how I installed it.
But would still like some clarification.
Thanks
Old May 10, 2011 | 11:58 AM
Coban's Avatar
The picture Matt@Texas-Speed posted should provide all the clarification you need. Did you look at it?
Old May 10, 2011 | 01:35 PM
CodyBoy's Avatar
Yea see it now, must have posted about the same time.
Thanks matt!
Mine looks just like that.
Pimpinpete
43
Dec 22, 2017 08:13 AM
OHsixLS3
Nov 22, 2015 07:45 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
sTNT971
Sep 26, 2015 04:22 PM
