-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   LS9 cam in a 4.8, what to expect? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/ls9-cam-4-8-what-expect-500403/)
sand man Apr 15, 2012 08:23 AM
a friend of mine wants a cheap good DD cam for hes NA 4.8
will this be a good choice?
its a reg cab NNBS so it got the big heads /intake/ and TB
Jake99 Apr 15, 2012 10:27 AM
I would not advize this cam on a na 4.8, looking at the numbers I think it would be slower anywere under 5000 rpm, the lsa is the big killer. I think an ls2 cam would be a better choice.
sand man Apr 18, 2012 09:17 PM
i want somthing bigger than the 212/218 ...somthing like 40hp 40tq
mongooseboy000 Apr 18, 2012 09:23 PM
my cam pulls good from about 2500- shift point which is 6700. its a 215/222 on a 113 with .602/.604
Beatdown Z Apr 18, 2012 09:27 PM
There's a guy on theturboforums.com that uses ls9 cams in turbo 4.8's. Not sure if he has ever tried them N/A though. He's on ls1tech too and his username is denmah.
Jake99 Apr 18, 2012 09:42 PM
Thats asking for plenty out of cheap replacement cam in a 4.8, I have a 212-212 562lift 112lsa in mine but its turbo, The power comes in at 3000 and pulls hard to 6500 were I shift it and im sure it would pull to 7200ish. Remeber at the same rpm the 4.8s piston is moving slower then any other ls motor, you put more dur in the cam you may move more air but your not letting it build any compression (no torque). What you want is less dur more lift tight lsa. Id go for something around 215 dur 580 lift and a 110-111 lsa unless you plan on running more then a 4000 stall.
sand man Apr 20, 2012 06:41 PM
how about a somthing in the 215 218 and 600 lift with 112-114
Jake99 Apr 20, 2012 07:57 PM
That sounds pretty close to me, gearing a stall will make a big difference on what you can get away with, this cam should work good with a 3000-3600 stall, you could bump it up to 218-222 if you had a 4000 stall.
sand man Apr 23, 2012 04:37 AM
cant afford a stall
Jake99 Apr 23, 2012 04:13 PM
Originally Posted by sand man (Post 4909704)
cant afford a stall
Is it a 65e or 6l80? Even with a stock stall I think these cam numbers will work fine I dont think id go any smaller, the 4.8s dont make a hole lot of power so a cheaper used stall would work fine, im sure hes going to want one sooner or later.
