LS2 + 60cc 862 Heads
Found a great deal on an LS2 shortblock. I already have a set of worked 862 heads. Wanted to know if compression ratio would be fine to run on 91 octane?
Specs on heads as follows:
Milled .010", LS1 2.02 intake valves installed, 5 angle valve job, mildly ported.
Going off calculations found on the web. I figure they're around 60cc. Cam will be a BTR Truck Stage 3 218/224 .553/.553 113+3. Going into a 2001 ECSB with a 4L80e behind it. Will be street tuned by Mark Roman.
