Lq9+243s in a RCSB
Ok guys so I picked up an 06 4.8l nv3500 5spd RCSB Silverado the other day to transplant my lq9 in.
I've purchased: Stock 243s (should I go with tsp stage 1 or 2.5s instead?) 10.9 to 1 comp with stock gasket 228/232 .600 .600 112lsa cam Ls7 lifters Pac double springs Chromoly pushrods Ls2 timing chain .040 cometic head gaskets 4.035 bore bumps it 11.3 to 1 I believe Arp studs Meiling high pressure oil pump 42lb drop in injectors Gmt900/tbss intake and tb Msd pro pack coils ls2/ls7 style I'll also be doing a coil power wire upgrade Plan to purchase: Speed engineering 1 3/4in long tubes and axle dump exhaust kit Nitrous outlet plate kit to run a 150 wet shot That being said I plan on swapping the nv3500 for a t56 magnum after I rip it out and doing gears at that time. My only concern is I'm not going with a big enough cam. This isn't a daily driver this is a toy if anything. I have a diesel to haul with so I'll never tow with it. What are guys running in manual RCSBs. |
The cam is large enough to make some steam. Do you know the ICL?
(Post 5412819)
I run an automatic so im sure it varies but, I run a 6.0 with ported 243 heads, tsp 228r 600/600 on a 110, nnbs intake with a 102 throttle body, longtubes and 4l80e automatic and run 7.60 to 7.65 on motor every pass down the 1/8th mile @4500lbs. That cam should work very well for you i would think.
