LM7 low end
LM7 low end
I was looking more power to my LM7 engine. First step was the camshaft shift. Camshaft I chose is "Cam Dynamics Low Lift NSR LS Truck Cam 224/230 .500/.500 112. CD13001 .But after dyno l see there is not all that way l wish. Torque should be middle or high end not low end. What can be wrong there? Today i was check cam posision, it seem in right place.
Cylinder heads are stock 862.
Any ideas?
Any ideas?
Custm2500's Rude Friend
This camshaft is very mild. It's designed to be used with a stock convertor and and stock valve springs.
Look at this Graph of the Comp 54-412-11 XR265HR 265/271 advertised 212/218 @ .050 .522/.529 Lift 114° LSA
Here is another from TSP. Texas Speed Low Lift 212/218, .550/.550 on 112LSA
The way I read the op is he was wondering why the torque peaked at 2800 and was hoping for a higher peak?
I was hoping for the momentum in the same area where the stock engine does 3000-5000 rpm. Why I want higher is that I would like to drive 1/4 mile. Rather, the question was whether it is a normal curve on such a puppet or restricts something else there. As I have already realized, I would have had to choose a more aggressive cam.
