Lifter Size
Putting in a new cam in my 383 stroked motor and want to know if I should get a bigger lifter.
The cam specs are 612/612 - 242/244 - 113LSA Will the LS7 lifter suffice or should I go with a Comp R or something comparable? Chad |
Bigger? Do you mean a better lifter? LS7's should work fine or if you want something even nicer that's drop in get some Johnson 2110's
