L92 reluctor wheel
What is it and do I need a 24x or 58x for a 416 stroker build?
If it's for your 08 then you'll want a 58 tooth reluctor wheel ;) It's a wheel on the crank shaft that the crank sensor gets it's signal from...the crank sensor has a magnet in it and it's signal fluctuates as the metal teeth of the wheel pass the magnet.
do I need to convert anything on the vehicle if the 58x comes on an assembled shortblock?
Originally Posted by Iraq Sucks
(Post 4435257)
so the more teeth, the more constant the signal is I assume?
(Post 4435747)
(Post 4435747)
And the best Part, GM is once again going to change the reluctor! The new one will still be 58 teeth, something about positioning. -Adam @ Callies
Originally Posted by Low_LQ4
(Post 4435759)
The 24 reluctors are for NBS trucks 99-06 GM switched to 58 wheel on the NNBS 08-10 trucks.
dame i learn alot in this fourm
| All times are GMT -5. The time now is 01:00 AM. |
