Idling problem after cam swap
Old Nov 6, 2011 | 11:56 AM
ihdude's Avatar
Default Idling problem after cam swap
I have a 6.0 that I just put an EPS 226/230 110 LSA cam in. The truck is now idling at 700 rpm but keeps dying. This is with a manual transmission. I have a trailblazer SS intake with an Edelbrock 90 mm throttle body on it also. I tried adjusting the idle screw on the throttlebody but it doesn't seem to change the idle speed any. The truck will idle fine but if you give it gas, it drops below 700 and dies out. Will a computer tune bumped up to 900 rpm fix this problem? Thanks in advance.
Old Nov 6, 2011 | 04:45 PM
2007chevy5.3l's Avatar
If its not tuned for the cam thats your problem..
Old Nov 6, 2011 | 05:34 PM
07blakchevy's Avatar
You need a tune with almost any if not every cam install, especially that one. Get it tuned it that will fix your prob
Old Nov 6, 2011 | 05:39 PM
budhayes3's Avatar
PT's Slowest Truck
As mentioned above, the PCM needs to be adjusted to compensate for the extra air and fuel that cam will be moving. Since it's idling fine, I highly doubt that the idle speed will need to go any higher, but MAF, VE, etc. now need attention.
Old Nov 6, 2011 | 08:43 PM
TheRepairMan's Avatar
Banned
plus 1 on the tune.
Old Nov 6, 2011 | 08:54 PM
01silvy's Avatar
Get it tuned and put the throttle body settings back the way they were
Old Nov 6, 2011 | 09:14 PM
Amedee's Avatar
Get with a sponsor on the right for a tune.
GrooveCityZ71
Aug 31, 2015 12:05 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
