how to measure quench
Old Jan 22, 2007 | 03:24 PM
TURBHOE's Avatar
Default how to measure quench
so how do you measure it and what is optimal?
Old Jan 22, 2007 | 03:27 PM
gao8302's Avatar
It takes me about a 12 pack to quench my thirst.
Old Jan 22, 2007 | 03:29 PM
thunder550's Avatar
High on diesel fumes
Quench is the distance from head deck to top of piston.
For example - my piston is .01 out of the hole, head gasket is .04", so my quench is .03" (.04-.01=.03)
I think optimal is somewhere in the .03 to .04 range, but don't quote me on that.
Old Jan 22, 2007 | 03:35 PM
TURBHOE's Avatar
oh well thats easy. lol i thought it was like measuring to a certain part of the head like middle of the combustion chamber or something like that lol. ok i totaly over thought that . i searched for how to measure and got nothing so i figured i'd ask .
Old Jan 22, 2007 | 03:50 PM
thunder550's Avatar
LOL I had no idea either until I built this motor.
Old Jan 22, 2007 | 08:15 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Most engine builders say LS1 like .037-.042
Old Jan 23, 2007 | 05:03 PM
TURBHOE's Avatar
so i called eagle and they said that the piston on there kits were made not to stick out of the hole. so i guess the .042 gasket by felpro would be best then? this is a budget build so i'm not in for really high price gaskets. no boost or n2o for now.
Old Jan 23, 2007 | 06:14 PM
1slow01Z71's Avatar
What are you building first? I have the Eagle "stroker kit", with JE Pistons and mine stick out .008 with stock deck height. I have read ALOT of bad exepriences over on tech with the FelPros others swear by them, it seems that the stocker MLS gaskets are a great budget option and actually handle boost and nitrous very wel with head studs they just pop easily with knock.
Old Jan 23, 2007 | 06:25 PM
TURBHOE's Avatar
Its a 383. eagle stroker with 4" crank and 6.200" rods. i found the pistons on je's web site and there site says +.010" deck clearance. it also says 10.5:1 cr with 72cc heads and .057 head gaskets. so i guess the stock .052" head gaskets would be good and set me at .042 if the eagle site is right. who do i believe eagle saying its got .000 deck clearance or je the people who make the piston and says its .010?
Old Jan 23, 2007 | 06:31 PM
1slow01Z71's Avatar
You sure its a 6.200 rod and not a 6.125, I dont see any need for the longer rod with only a 4" stroke unless they are using pistons with REALLY long skirts.
