how big of a difference
Old Jun 14, 2010 | 09:21 AM
jmj85's Avatar
The 224 may max performance, but isn't it going to kill my towing? I where I live I've got foothills and tow over a mountain pass or two, and can afford to lose alot of low end.
Old Jun 14, 2010 | 02:07 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I honestly for once agree with comps recommendation, a 220 duration would be the biggest Id put in there.
Old Jun 14, 2010 | 02:37 PM
jmj85's Avatar
thanks slow
Old Jun 14, 2010 | 03:16 PM
Spoolin's Avatar
GFYS and STFU
112 vs 114...
For what you looking to do, get a cam with less overlap, the more overlap you have the more you'll hurt your low end. Overlap is good for making power on the top end since the intake velocity at those RPM's is enough to overcome the exhaust pressure for that slight moment that the two valves are open together, also helps scavange any remaining exhaust out of the cylinder. However during Low rpm driving the intake velocities are not enough and you end up with some intake reversion which is why you hear your motor lope.
zblee
Nov 11, 2015 12:41 AM
Tigger Welder
Oct 1, 2015 08:41 AM
MOBBN
Sep 11, 2015 08:34 PM
TrickTurbo
Sep 10, 2015 11:46 AM
