How bad is it to?
i think standard operating pressures should be around ~58 psi... as long as your AFR is okay, i would think its safe.
11.5 sounds about right for FI... IMO you should be fine.
would like to see it a bit higher at WOT though.
another question ... what your fuel setup?
looks like your a H/C with a supercharger? hopefully you are at least running a larger pump that can keep up.
what size/type pump are you running, and what size injectors?
