Help
Old Dec 5, 2012 | 09:53 PM
tb8125's Avatar
Default Help
Here is my set up
Lq4 317 heads with ls6 springs (blue) ls6 cam , ls7 lifters and ls9 head gasket with arp studs
I want to know should I have do new bearings and call it a day
Old Dec 6, 2012 | 06:12 AM
Gadgetized's Avatar
What are you trying to do to it? Explain more about your problems, symptoms, or goals please.
Old Dec 6, 2012 | 10:56 AM
tb8125's Avatar
I bought the motor for a swap.... I never had it running and I want to make sure the motor is good and sound before installing... I have a procharger that I plan to install.... My biggest concern is the rings and bearing I want.... I have another block that I was going to really build just want to get going for now.... I was thinking of just rolling the dice letting seeing happens if install with out installing bearings and ring..... My only thought is I had a lot of sludge like it wasn't really taken care of....
Old Dec 7, 2012 | 11:01 PM
geareater's Avatar
Well, unless you heard it run before you bought it, you'll never really know. If its stock, and you just put on what was listed above, I wouldn't worry about it too much. Did you happen to get the mileage?
Old Dec 8, 2012 | 10:58 PM
tb8125's Avatar
No mileage but this is what it looked like when I took the heads off
Looks like the missed a couple oil changes
Old Dec 8, 2012 | 11:00 PM
tb8125's Avatar
And this
