FI/ cam
I'm looking to go to forced induction as well as upgrade to a bigger cam however I'm not sure which to go with first.
I suppose it will come down to what kind of prices I can find for what kinds of performance gains each will offer. So if anyone is considering selling turbos/superchargers by themselves or even as a whole kit, or if anyone is selling a cam and other necessary engine internals let me know. Thanks! Alex |
Figure out if you want to go with a turbo/ Procharger/ or other supercharger. Each one will want a different cam. I would get the F/I first
I knew that its better to choose a cam designed for forced induction but I was unaware that every form of fi required specifically designed cams.
Another thing on my mind is whether or not I should get a cam that utilizes vvt or a setup that eliminates it.
Its my understanding that the former will provide more torque with a broader range of power where as the latter will provide more HP however it is more "peakier". If that's incorrect, let me know, however even if it is correct I don't know which id prefer because I haven't had the luxury of experiencing either. Any one with some personal experience care to jump in? Thanks Alex |
turbos have alot of exhaust back pressure. superchargers need a free flowing exhaust.
So turbo cams have single duration say 220/220 vs a supercharger where you will see something like a 218/228 since its getting air ramed down its throat and needs more exh duration for it to get out of the engine. |
We offer options for both setups with the vvt or without, personally I would keep the vvt setup, as you are able to control more valve events and potentially make more power. Feel free to give us a call, we can certainly help you out in spec'ing a camshaft for your application.
IMHO, a VVT cam is a "compromise" cam. No thanks.
Beyond that, get boost first, then go from there. |
Jake, thanks for the help and lowrider, can you elaborate?
Go boost first, then decide on a cam. If you do it the other way around, you run the risk of getting a cam not ideal for your setup
D: Tis so expensive.
And yes I know "gotta pay to play" or whatever. Id just really like to get some more power but the only ways I'm seeing to gain anything really noticeable is either a cam or turbo/supercharger and they're both gonna cost me but I think I could get the former for under a thousand where as the latter is going to be at least 4-5 times that. Suppose I should turn my studying entirely to forced induction and attempt to find deals. Now that I got my bitching outta the way. Tx Tahoe, how has that Radix been treating you? Like it? |
| All times are GMT -5. The time now is 06:15 PM. |
