Eps truck torque 1 cam?
in a 4.8 it will be noticeable. I would call Geoff and get his take on it. No one knows that cam better than he does. I dont know what advance it has ground in, or where it will leave your dynamic compression or any of that... hard to really answer questions without knowing those variables.
You should post the specs of the cams you're questioning. The TU0 is something like 215/215 whatever lift and 115LSA, right? If so, that could be a somewhat mild sounding cam in a 4.8. The tune has a large effect on how the cam sounds at idle too, so keep that in mind.
07NBSChevy
20
Jul 8, 2015 07:27 PM
