Eps 222/226 cam
Anybody run a EPS 222/226 .598 113lsa cam or cam with similar specs?
From what i gather it is a tr224 style with more kick. EPS has it listed as a ls1 cam.Many LS1 cars cam only made real good power with it.400+ Wondering if anyone has tried this in a truck? |
ive been running it for almost a year.
baby cam in a 6.0. good mid range, top end falls off fast past 6200- 300. Lost some power below 2500 or so. |
How do you like it? Thats in your 6.0?
that cam would be good if you threw some 243s on your truck and bumped the compression up a bit.. That lift is alittle high for stock 5.3 heads I think
lookin at prc stg2.5 5.3 heads to go with this if i pull the trigger on a new setup
Not to sure on cam choice just yet still lookin |
Originally Posted by GMCtrk
(Post 4603579)
baby cam in a 6.0. good mid range, top end falls off fast past 6200- 300. Lost some power below 2500 or so. stock 317 heads? |
ported heads, 10.6:1 comp
makes about 475-480 flywheel based on logging and I'm guessing around 360-370 rwhp thru 80e. would be a nice cam on a 5.3, probably pull nice up to 6800. |
Originally Posted by Bumpers
(Post 4603640)
With the prc heads and this cam it would be a monster 5.3.. I have rode in a 5.3 with the same duration but alittle less lift and it pulled pretty well I think it would really run good with what your wanting
what does eps stand for?
| All times are GMT -5. The time now is 01:11 AM. |
