electric water pump
Old Dec 7, 2008 | 10:19 AM
whitegmc2002's Avatar
Question electric water pump
im thinking about a electric water pump for my 5.3..wondering how much it would benefit and who makes a good one...its a daliy driver about 30 miles a week...but its about to be driven just on weekends..
Old Dec 7, 2008 | 10:27 AM
i also have 706 heads they came on the truck new are they worth doing any work to or do i need to find some other heads??
Old Dec 7, 2008 | 12:50 PM
sickREDsierra's Avatar
normal pick up is about 10 hp from taking the WP out of the loop..
706 heads are fine to be worked, but by the time you put new springs, upgraded stainless valves, clean the bowls, port/polish the chambers/runners, 5 angle valve job, and mill them.. you could most likely but some nice TSP heads, or WCCH heads..
headwork i mentioned will run you around $800 without the springs and new valves.. and retainers, valve seal, etc....
give Richard at WCCH a call and talk it over, very helpful guy. or you can buy these dumbass Patriot heads i have
Old Dec 7, 2008 | 04:13 PM
thanks..
why dont you like the patriot heads??
how about some afr heads??
Old Dec 7, 2008 | 04:52 PM
joshua022's Avatar
afr are great, but really expensive..
Old Dec 7, 2008 | 06:50 PM
krambo's Avatar
Meziere LS1 EWP here. You will need to space it out in order to align with your current truck accessories and cut your upper radiator hose to fit. So far I am enjoying it.
Old Dec 7, 2008 | 09:00 PM
Noah Burns's Avatar
how did you space your's, and how much? looks like its still pretty close to the belt not being on the pulley
Old Dec 9, 2008 | 05:12 PM
krambo's Avatar
It is spaced the equivalent of 4 gaskets on each side. Any more than that, I would suggest longer WP bolts. I have driven it, blipped the throttle, hit 6300rpms, on and off the throttle hard and never threw a belt. Sure it can be spaced more however in my case, didn't need to be.
Old Dec 9, 2008 | 05:18 PM
dirt track racer 81's Avatar
if your truck is a daily driver i wouldnt get one. not reliable in my opinion. Ive seen one fail on a ford and one a c6 zo6. both meziere
Old Dec 10, 2008 | 01:49 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Not for nothin' but the mechanical WP on my wife's AV failed at 17,000mi.
The research I've seen shows that these are now reliable, DD quality pumps.
I putting the same one Krambo uses on my new 427 (tho it's not going to see DD duty).
