Dyno
anyone with a 5.3 with a small cam that has a dyno sheet and is
willing to share ? i am looking to compare it with mine. I am getting a new tune and want to see diff tune results. if you don't want to post it you can e-mail it to me, turboal@aol.com no one will see it but me. I need all the help i can get . thanks in advance AL |
4300rpm, 255hp, 310tq(peak)
5575rpm, 300hp(peak), 285tq 5.3 with isky triple 12, heads shaved to get 10:1 cr, cai, efans, and this was with a base tune. If I had to guess, now Im more like 315hp@6000 and 330ft/lb@4500. Shifts are now 6300 and pulls great the whole way. |
tune
my base tune was 285hp/6350- 294tq/4000 on 87 octane and 95 deg temp.
going back when it cools down a little with 93 octane for retune. |
Here is an old one I did many years ago. If I remember later we cut the cats off and put on a K&N hot air kit and I thing we got the RWHP up to a little over 320.
https://www.performancetrucks.net/fo...y-dyno-360357/ |
tune
that is outstanding, i would like to get that out of my swap.
do you still have that tune file ? |
Haven't dynoed yet but did just install a Cam Motion Stage 2 drop in cam for testing. 205/210 .510/.510 115+4
Baseline was 220rwhp/240rwtq for a 2nd gear pull unlocked converter (stingy dyno). Maf values went from just under 29 lbs/min to 34 lbs/min Full review will be up as soon as I get back on the dyno and get some MPG numbers |
99's have like 19 lbs/hr injectors from the factory. If you haven't upgraded, then that could be holding you back.
Injector duty cycle is at 88% WOT. I have a set of the later injectors I can put in. But I will probably wait until I put on headers and retune for everything at once.
Not really concerned with the numbers, dynos are just tools. I have seen a head/cam/full bolt on ls1 car with manual transmission make under 400rwhp on this dyno. |
| All times are GMT -5. The time now is 08:54 AM. |
