-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Connecting Rod Math question? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/connecting-rod-math-question-353737/)
moregrip Dec 1, 2005 10:33 AM
Need a sanity check on my math:
Since there are "stocked" pistons made for a 4" stroke Crank using a 6.125" Connecting Rod.
Shouldn't I be able to run those pistons with a stock stroke crank(3.622") and a 6.314" connecting rod or there abouts?
Okie5.3 Dec 1, 2005 11:41 AM
right on the money, assuming a measured DH of 9.245". you'd be looking at what a 71% rod/stroke ratio.
moregrip Dec 2, 2005 07:53 AM
cool, thanks for the math check :usa:
TurboGibbs Dec 4, 2005 12:37 PM
You could run a 4.8 rod (6.285) and deck the block .030 and have the same thing for a lot less money. :judge:
vanillagorilla Dec 4, 2005 01:27 PM
To tell where the piston will wind up in relation to the deck, I always use deck height-1/2 stroke-rod length-comp height. + number= out of the hole, - number= in the hole, 0=zero deck. :)
So with the two compression heights being the same:
9.245"-2.00"-6.125"-X=9.245"-1.811"-6.314"-X
You are correct sir, but where are you going to get a rod with that exact length? Custom? Titanium perhaps?
TurboGibbs Dec 4, 2005 02:33 PM
That is why I suggested the 4.8 rod.
A custom set of pistons and stock rods would be a lot cheaper than pistons and custom rods of course as well.
vanillagorilla Dec 4, 2005 03:14 PM
Those would put him about 0.029" in the hole, assuming the off the shelf stroker pistons are at zero deck with the 4" stroke/6.125"rod combo. It'll drop his compression ratio quite a bit too. :)
mattrem Dec 4, 2005 03:27 PM
The 4.8 uses a longer rod? interesting.
Okie5.3 Dec 4, 2005 05:03 PM
that would leave him with a CH of only .93". that would make for a lightweight piston that's for sure. wouldn't you run into some piston rock unless tolerances were dead nuts on???
TurboGibbs Dec 4, 2005 06:26 PM
See post #4.
"wouldn't you run into some piston rock unless tolerances were dead nuts on???"
The length of the skirt controls that.
