-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Comp LSR cams? 215/223 on a 112 LSA? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/comp-lsr-cams-215-223-112-lsa-447716/)
ForkHorn Sep 7, 2009 04:26 PM
I have been browsing the forums and searching for a cam that will suit my needs, and what seems to be the needs of many here. A torque, lower rpm cam with decent gains across the board. Something like the comp 212/218 or tr220.
Recently I came across the Comp LSR line of cams, and the first in the line stuck out to me as something that might fit this application. Here is the specs: http://www.compcams.com/Cam_Specs/Ca...csid=1399&sb=0
215/223 on a 112 LSA. Seems like a pretty good combo. May even have a decent idle.
So what's the verdict? Any experience? Opinions? All is welcome.:hail:
02_Orange_D1SC Sep 8, 2009 04:08 PM
from what ive heard these lsr lobe cams should do very good in a 4.8 or a 5.3
Red04Silverado Sep 8, 2009 05:10 PM
Whats the lift on that cam?
budhayes3 Sep 8, 2009 06:38 PM
Originally Posted by red04silverado (Post 4284650)
whats the lift on that cam?
.604/.61
BlackGMC Sep 8, 2009 07:03 PM
WOW, that cam has a ICL of 107.... I have never seen a off the shelf comp cam with that much advance....
Cakes Sep 9, 2009 05:17 AM
I do not have the cam mentioned but I have a custom cam ground using Comp's XE lobes and similar duration/overlap/advance specs. (see signature). There is a short idle clip of the cam just after the install on my "Photo" link. I wanted a custom cam since my truck is a bit heaver (i.e. 4x4) and I use it as my daily driver. I would say it gained me a nice chunk in the midrange and some decent gains up top too. NO low end was lost either. I would think the new LSr lobes would give even more power than my puny (realitevely speaking) XE lobes. I would not mind upgrading to an LSr cam in the future. Let me know if you need anymore info or even a video.
charcoal03silvy Sep 9, 2009 09:40 AM
that's a lot of lift too it seems like.
Red04Silverado Sep 9, 2009 12:17 PM
Damn thats some lift.
charcoal03silvy Sep 9, 2009 03:46 PM
says its great for 4.8/5.3s, hmmmmm.
Edit: Can't find a video on youtube with that cam.
Red04Silverado Sep 9, 2009 05:46 PM
Wonder how this cam would do with high flow 5.3 heads mill .30 on a 4.8 ;)
