check engine
Whts up guys! Wondering if ya can help me out on my problem. Well my check engine is on cuz of my m.a.p sensor n my m.a.f sensor. Well my m.a.f is good, there's seems that there's no current going thru. Cuz I re-wired it last time cuz my intake pope out n the wires riped. So wired it together. But it stills shows it on the dignostics. So any suggestions??? Would be helpfull. Thnx guys.
It sounds like there might be a loose wire in the connector. Double check all wires are connected correctly, then if you can check frequency output and IAT on your scan tool that should verify that it is hooked up correctly. Have you cleared the codes since it ripped the wires out?
Yea. I checked the wires n there good n tight. N I have cleared the codes.
Can you describe your engine set up? If you are exceeding expected MAP/MAF parameters you can come up with some codes.
When I was getting a re-tuned my maf meter wouldn't move at all, even when I put a new maf. n the codes, I got them from auto zone.
