Lq9 cams....i already used the search function for the past week lol...
Old 03-09-2008, 12:04 PM
Ws6Luvr's Avatar
Default Lq9 cams....i already used the search function for the past week lol...
my 5.3 motor went out and Im in need of a new motor...I'm searching for an lq9, but while the motor is out, I'm going to go ahead and throw a cam in there.
I do not regularly race my truck....if someone is acting a jackass, i'll put the pedal down on them, but i do not actively race it. I sometimes tow cars and haul stuff. I don't plan on a converter just yet (if i do it'll be a 2600 or a 3200 yank stall) I would like more power throughout the powerband, as well as more torque. The truck currently has ASM longtubes and x pipe, true duals magnaflows. Plan on doing electric fans this summer.
I am wanting suggestions on cam's for the 6 liter lq9... please help me out!!! lol i've been out of the game for almost a decade so I'm not as savy as I once was when it comes to all these things hehe..
thanks a ton!!!
Nate.
Ws6Luvr.
Old 03-09-2008, 12:09 PM
Mr. Obvious
nightrunner's Avatar
probably something close to a 216/220
Old 03-09-2008, 12:24 PM
TrailLaser's Avatar
Try going with a torker type cam with some power to boot... A Lingy GT2-3 seams to work well in the TBSS's, should work in a full size p/u as well..
Old 03-09-2008, 01:03 PM
03sierraslt's Avatar
A good torque cam would be a Comp 212/218 low lift on a 112 or 114lsa.
Old 03-09-2008, 01:08 PM
gao8302's Avatar
I have a 216/224 551/551 115lsa for sale. Its a vinci trucker cam. Its a great cam. I will sell it for 250 plus shipping. It has less than 3000 miles on it. Let me know if your interested.
Old 03-09-2008, 01:31 PM
InchUp's Avatar
Something of the sort will be wonderful in a truck that wants power across the RPM band. This is the same cam I am going with in my LQ4 build, and this was custom ground for me by a CompCAMS expert. I do say expert, because he's done over 1000 cams for Lingenfelter builds and spends his free time with CompCAMS grinding custom camshafts. Look at my Avatar and signature to see why I cannot afford to lose any low end.
Duration @ .050 218/ 224
Valve lift .562/ .567
Lobe separation angle 112degrees
Intake center line 108degrees
+4 advance
In an otherwise stock LQ9 with long tubes and E-fan you're looking at an easy 405hp, 410lb-ft of torque with no loss of truck pulling power.
Old 03-09-2008, 03:00 PM
brobradh77's Avatar
The GT2-3 is a blower cam and IMO wouldnt work well in a N/A application. But who knows??
Old 03-10-2008, 04:08 AM
TrailLaser's Avatar
Im running this cam in my TBSS.. I pushed 383/383 with 12.9 afr.. Need to dial in a little more and drop down to 12~12.25 afr and she'll be good to go.. Not much power past 6100ish, but an overall good cam without having to change the springs.
Old 03-10-2008, 05:28 AM
You should have changed the springs with that cam, the stock springs are meant for a cam with .571-.578 lift. I dont doubt its better then the stock cam but there are much better NA choices out there. The GT2-3 is a blower spec cam with a very large exhaust bias, and therefore a low intake duration. A NA 6.0 can easily have a intake duration in the 22x-23x range, as opposed to 207.
Old 03-10-2008, 08:44 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Take a look at the Vinci 079 (the "Ultra Torque") -- won't need a converter, doesn't require a retune, will give you lots of torque.
Yes, an LQ9 can handle a 22x-23x on the intake, but won't flow enough to require that much. IMO 22x - 23x on a 6.0 is too much -- not to mention that it will require a new converter and lots of tuning. For a DD cam given the stated intentions of the OP, smaller is better. Heck, in almost every situation, smaller than the max the motor can handle is better IMO.
I run a 23x with an FI 408 on race heads so that should explain how I feel better than words
Quick Reply: Lq9 cams....i already used the search function for the past week lol...
