Cam Swap = Oil Pressure Loss
Old Mar 29, 2009 | 09:15 AM
hirdlej's Avatar
Has anyone stopped to think that maybe the actual cam bearing journals are too small? Did you measure the cam journals on your old cam vs. the new one you installed? If it's off even 2 thousands I can see that being your oil pressure loss. You can install a new gm high volume pump for $80 or measure your stocker and yank out the aftermarket one and compare. I don't like low oil pressure in engines.
Old Mar 31, 2009 | 09:43 AM
budhayes3's Avatar
PT's Slowest Truck
+1, It's probably a size difference in the camshaft itself where there's more clearance between the cam and the bearings.
Old Mar 31, 2009 | 09:49 AM
Coban's Avatar
Yea, I did, a few posts up....
Originally Posted by Coban
..... I just figured the clearances weren't as tight.
Old Mar 31, 2009 | 09:55 AM
budhayes3's Avatar
PT's Slowest Truck
I did lose a little bit of oil pressure after my cam swap. Less than 5 psi though. I just figured the clearances weren't as tight.
Yea, there it is...missed that somehow, sorry...
Old Mar 31, 2009 | 11:58 AM
FarmerBeau's Avatar
Sexy Party Mod
Did you remove the oil pump in order to change the timing chain? If so, check your pick-up tube o-ring. If not, you are probably looking at changes in clearances.
Old Apr 6, 2009 | 05:25 PM
Slimsilverado's Avatar
Yall are running low pressure, my 01 idels at 50psi and runs 75 - 80 at WOT
Noah Burns
Sep 7, 2015 05:50 PM
Suburban2500
Jul 19, 2015 04:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
