cam help for 6.0
i need some suggestions on a cam,pushrods,springs for my lq9 6.0.
Vehicle- 05 crew cab 2wd daily driver when i can afford gas for it lol 4.11 gears yank tt3000 stall 799 heads are going on tbss intake obx long tube headers |
TSP torquer V2 is a 232 236 IIRC. Would work good for that setup. Could go a little higher, but i'm not a huge fan of big cams.
Originally Posted by charcoal03silvy
(Post 4732426)
try the 228r with 3600 stall :p
The tt3000 is a tight converter and you got a fairly heavy truck, but the 799 heads will bring up cr so that will help you get away with a little more cam, I agree on the 228r cam for your setup, it should work good with you stall still I think, but also gives you room to improve to a higher stall later once you want some good 60 foots.
if your planning on staying with your current converter i wouldn't go any bigger than a 228. i think a 224 would work nicely with your setup
you ahve to remember that your truck is heavy, bigger isn't always better.. |
Originally Posted by pewterliftedz
(Post 4732486)
as far as exhaust goes, it's headers going into a cat less y merging into a single 3 inch. I,m considering a 34-3600 stall, but i tow my bike, lawn mower and a car from time to time. don't want to loose the ability to do that.
EPS Truck Torque 3 - 224/230 .609/.607 111 LSA
Originally Posted by Beatdown Z
(Post 4732640)
