Cam ?
I have a 5.3 with headers hiflow 4l60e 3.73s with intake and tune and I was wondering wat would be a badass cam size for that will help me out from start to finish
you planning on getting a stall? you pretty much need a stall if you want a decent cam to work good, stock stall maybe 212-218 530 lift 110lsa, 3000 stall tr220, 4000 stall 228r. Thats kind of a base line that can help you on size, custom ground cams dont cost any more then off the shelf and that might be your best bet, find a good cam grinder and have them build you one. pat g makes good cams.
I have a 3200 stall on right now
Originally Posted by cammed5.3 210
(Post 4822866)
What RPM do you want to run to? Planning on a new set of head/rework your current heads? What year is it? This will determine if you have 706 style heads, or 243 style heads. As well as your CR. |
Im running the tr220 with a 3200 stall and it does pretty good. but would run way better with a 3600
Extended cab 2wd 05 5.3 I want to do head work in the future
Comp 216/220 low lift works for me.
Reg cab, 4x4, 3.73, 3200 stall, 243 heads, broad power range and shifting at 6200. May be able to go a little bigger and look at something like a TSP 220, or a TR220. But that's the biggest I'd go. After cam and head work, you may have a fueling issues, since I currently don't have enough fuel pump with my setup. My fuel pressure drops off bad at 5400. |
R your heads ported and polish and if they r how much did u port them and wat r u runnin in the 1/8 and 1/4
They're stock 243's milled .030 to bump compression back up. Wasn't able to hit the track this year due to the near biblical flood we had all summer. I'm going to hit the track in the spring, but first I have to get a different fuel pump.
According to my Areoforce Interceptor.. my quarter time will be somewhere around 13.8 probably +/- .2 |
Well the other day I called tsp and the told me I was better of with a custom grind cam and he told me that the specs would be
220/224 581,581,112 what y'all think bout that cam |
| All times are GMT -5. The time now is 03:10 AM. |
