Broke a valve spring HELP
Like the title says. I broke a PAC 1518 650 lift behive valve spring with only 3,000 miles on it. I pulled the valve covers off yesterday just to check everything out since they haven't been pulled since the cam swap and sure enough one was broke. I never heard a rattle or tapping so I cant tell you how long its been broke. Truck doesn't run weird or anything. like I said I was just checking everything out and saw it. question is can I buy just One spring or do I have to buy a whole set. there were $250 from texas speed. Or should I say screw these and go with something different. Hopefully if Im lucky the valves not bent and I can just put a new spring on and keep trucking.
http://i1178.photobucket.com/albums/...alvespring.jpg |
If it were me I'd take them all off and get another set of spring. If one spring broke another could break as well.
that sucks, I have never seen a set of Pac 1218 or 1518 springs break.
Just get a new set of springs like dirt track racer said. |
Originally Posted by dirt track racer 81
(Post 4565815)
Originally Posted by Tootall
(Post 4565826)
Originally Posted by KDavis04ss
(Post 4565828)
I never heard one single thing bad about these springs so hopefully it was just a fluke. If i did go with something else what would you recommend?
(Post 4565857)
I'll never run or suggest a single valve spring.
Kyle, I just emailed you on this but figured I'd post it here in case you don't check your email so often. They (PAC) just want you to ship that broken spring back to them, and they're going to send a complete set of replacement springs out to you today!
Check your email for more details! :) |
Originally Posted by Matt@Texas-Speed
(Post 4566256)
